ba.edwards-HT
I think that my hydraulic pump is consuming itself. My 2610 has 56hrs on the meter and in the last 10 hrs or so I have been experiencing a lack of performance; the front bucket basically will not pick up more than maybe 10 lbs (my guess). I decided to change the Hyd Fluid this morning and after letting it drain for a while I noticed small particulates on the internal filter. since there is a small amount that remains within the "drainpan" I inserted a small magnet and moved it around the remaining fluid and boy was it covered with large, curly-Q metal shavings. Large meaning that if i straightened them out they would range between 1/4 and 3/8 inch.
Once I find the culprit (I think it is the Hyd pump) I still need to flush the entire system to remove any large shavings that may still be floating around in the system.
Does anyone have any thoughts or similar experiences???
Brian
Brian
