balancing a JD 50
Johnny50
I'm a rookie puller. Did some weighing this afternoon. right now in the 5000# class I have 25% weight on front with 10# air in tires
In 6000# class weighed up with 23% on front and will run 11# air. Can I improve this as a starting point? Lots of room to move weights in the 6000# , Not much in the 5000#
Thanks for any comments
You gotta start somewhere, so what you have is as good as any. Look at your spin-holes after the 1st hook, you want a flat footprint in the bottom of the hole(side to side). If cupped down, too much air, and cupped up- not enough air. Adjust your front weight in the 2nd class based on the first hook. A lot depends on the track, your tires, sled/chain length, hitch height, phase of the moon, and probably a few other things as to the right combo. Keep your hitch as high and short as the rules allow as a starting point. Good luck, Mike
I believe that I usually have about 33% on the front . But a very big factor is how well you hook up and a big part of that is the track surface. If everyone appears to be spinning out take off the front if everyone's front is coming up put more on the front.A few weeks ago the sled operator set up with his hook chain nearly horizontal and the track was on the soft side, this meant put it all on the rear because your not going to hook up. good luck!
