Bale fork modification
SVcummins
Made my bale fork so it will mount on my buckets on either loader . I would like to go to a quick attach system some day but for now I need to spend money on other things . Hopefully I made it heavy enough selling some hay tomorrow so we’ll see how it holds up I put a one inch bolt in the center .
The difference I would make is to set the frame on the front edge of the bucket with an angle welded to the front edge of the frame so it would not slide back then a chain around the whole bucket or or through a hole in the angle to keep it from falling out then just a stop on the back at the top. Ours just has a 3/8 angle about 6 inches deep by 4 inches with the sockets welded in to the 4 inch side then the 6 inch side sets on the bucket lip. There ar a couple pieces welded to the ends of the angle going under the bucket with a cross bar. The chain hooks to the cross bar and goes up over the back of the bucket to a loop welded to the angle then a binder to tighten the chain this gives support to the bucket and hols the forks on at the same time. Been using it for 15 years with no bucket problems in that time. Could get some pictures later today while I'm out there.
I’ve decided It’s back to the drawing board I’m going to make it so it will hook on the loader arms directly . It’s not bad loading big bales but when I load my 2x3 bales I can’t see what I am doing . I will have to widen the frame where the pins go buy about a foot to make it work
I came to the same conclusion when I made some bucket forks. It darn hard to see what you are doing with a big ole piece of steel in the way!
(quoted from post at 20:17:00 01/12/21) I came to the same conclusion when I made some bucket forks. It darn hard to see what you are doing with a big ole piece of steel in the way!
ried it & abandoned for same reason....sight.
..................also, bucket so much wider than bale, it makes stacking in barn very difficult.
I took a piece of 1/2" by 3" flat bar about 4' long and bolted it down to the holes for the cutter bar with extra long bolts. Then welded 2 pad eyes on the bar so a regular 3 point bale hook can be put on. I have to unbolt one pin on one side so I can slide the other in so I had to get the spacing just right to do that. Haven't got around to putting a couple pad eyes on top for a top link so I use a chain to hold the top. Will post a pic later.
