baler without a shed???
Anonymous-0
Hey folks,
After fishing my baler out of it's parking place and through the barn (couple hour job), I've decided it won't be going back to the same place.
I've got a heavy tarp (tractor trailor cover) for it and an old silo bunker that I can park it in to keep it out of driving weather.
What is the most critical part to keep dry?
Twine is all covered. Knotters and the pickup (gathering?) forks are open. Was thinking to make a flap cover from a mud flap or similiar for the knotters and then trim the tarp down to just cover the pickup area and use some twist or thread type fasteners so things look neat.
Around where I am a lot of us use a piece of rubber roofing. The piece I use is about 4x8. I got it from a construction site. I cover pretty much just the bale chamber area. The material holds in place well with just a couple of small weights and the twine bin holds both the cover and weights.
Dave - an old time custom baler told me to liberally grease the bill hooks immediately after each use, even if it was shedded. S'posed to help it start out tying good on the first bale. In fact, I smeared grease on all the shiny knotter parts. Even a light coating of rust can cause intermittent tying 'til it's worn off.
A shed is a baler's best friend.
Paul
If you do store it that way, make sure it gets
ventilation under the tarp. Condensation on the
parts is just as bad as rain. I second the comment
about greasing the parts well. Best thing would be
to get an operators manual and see what the
manufacturer recommends for putting it to bed for
the winter.
HTH
Christopher
Before parking it outside, even under a cover, fire up the air compressor and blow every last bit of hay chafe out of every nook and cranny. That's what really kills hay equipment - the chafe soaks up moisture and holds it right against the steel - might as well be acid.
I have a neighbor that has parked his baler outside it's whole life, that being a 1958 NH66 baler. He cleans all of the hay and chaff out of it. He then takes a quart of 30w oil and a gallon of diesel fuel. He put that mix in an old pump up hand sprayer. He sprays the inside of the chamber real heavy. He sprays the whole baler inside and out. Then he puts a waterproof tarp over the whole thing. He uses nylon rope to tie it to the baler.
This baler is in very good condition and appearance.
Poor thing.
Lot of stuff can sit outside.
Balers & combines can't.
Ya got a shed, give it a home.
--->Paul
