ballast box
41B-boy
Location
Chehalis, WA
Howdy, needed a ballast box/weight to put on 3 pt to counter the front end weight whilst using the forks...
Question for the brain trust regards the weights of various materials... sand, gravel, dirt, cement, etc.
What might y'all suggest that will give me the most weight in a 5.3 CF box.
I'm reluctant to use cement as it would permanently limit my choices in the future.
Anyhoo, have at it !
I'm all ears.
Fr. Bob
ps. John Deere 1070 with fluid filled rears
What I do is have my back blade on and on the center link area it has a wheel weight. Then the blade it self has 6 85lbs suit case weights hanging on the blade. Wheel weight is around 150lbs. I've tried a barrel filled with concrete but found the blade is far better plus you have the bale to use
How about something like this?
It's about 450 lbs less per yard, here than gravel, plus if the dirt is dry and lumpy, you don't have a true yard on the truck!
What I've always seen around here on barn tractors is a half barrel of concrete.I have one I took off a JD 300 utility with a 145 loader.The guy had mounted a vise on top of the concrete too.I use it for an outside vise table,and have used it a lot for changing U-joints in the warm weather.
I have a half a barrel poured full of concrete, with a drawbar sticking out the back so I can still pull trailers. I don't use it very often, so I don't have a picture. In the winter I have a back blade on, and most of the summer the brush cutter is on.
55 gallon drum set up for 3 pt. It's what I use. Right at 1200 lbs full of cement. Put it on or take off to use rake or back blade. Ford 3600 with a loader. 55 gallon is 8.82 cubic feet. So your 5.3 at over half would weigh about 750 full of cement. It's about 145 per cubic foot. Could leave it in the bag and soak it. Then could have 80 lb weights to put in the box. Or use the smaller bags.
A 55 gallon barrel works great. Run the lower links through the front third (not in the middle) of the barrel to allow for clearance without moving/removing the drawbar. Add a hitch on the back and place another horizontal bar in the back third of the barrel in case one needs additional weight (via front end suitcase weights) for a different tractor down the road. This will be about 1,200 pounds. Fill part way with concrete and finish with gravel, etc. Remember in this setup water will rust out the barrel eventually. I filled mine with 1 inch of top with concrete. This left room for a chain, etc. on top with little chance of it falling off and getting lost.
As others have stated, sand, gravel, dirt... all pretty much the same weight give or take.
Really, anything is better than nothing.
If you want to re-use the box, use dirt sand or gravel, whatever you have handy.
IF you don't care about re-using the box, fill it with concrete.
You could also build some forms and cast concrete blocks to fit the box, so they can be added and removed as needed.
That's a good idea to not fill it full, for a place to carry a chain. I did fill mine full, and I used a white plastic barrel that isn't UV resistant, so it's falling apart from sitting out in the sun. It still works fine, just doesn't look so good.
I've built 2 ballast weights
The First one was for my neighbor. It was a 55 gallon
full of concrete, estimated weight 1200#. He used it to lift 1200# round bales.
This ballast is not a full 55 gallon barrel.
estimated weight 900#.
That was enough to lift this heavy metal brake that is about all this tractor can lift.
The concrete is part of the structural strength of the ballast.
I have two Kubota ballast boxes (small and large).
I have bagged playground sand in each, allowing removal if/when desired.
Bags weigh 50 Lbs. each.
Dean
FWIW: I store each ballast box on HF moving dollies allowing easy hitch-up and movement when necessary.
What you have is super nice.
I'm cheap. Most used metal weights sell for about a buck a pound.
A 1200 concrete ballast =$1200 ouch..
A bag of portland cement = $10
Sand and gravel is free in my lower yard, old gravel pit
I have this carrier on my MF 202. I installed the supports that go from the upper center pin to the lower three point ends to take the load off the lift system. I was going to make something similar but it was actually cheaper to purchase.
