Ballast Resistor, MT wiring .
M. Davis
I'm putting my MT back to six volt and the wiring diagram doesn't show a ballast resistor. If it needs one, where in the system should it go.? Thanks.
The 6 volt MT used a 6 volt battery, therefore theres no need for a voltage dropping (12 to 6) ballast resistor. If it were a 12 volt tractor that still used a 6 volt coil, the voltage dropping (12 to 6) ballast would be necessary.
If youre at the ORIGINAL POS ground, the coils - wires to the Ign switch and + to distributor. Opposite that for Neg ground.
A small relatively easy to crank over M should work fine at the original designed 6 volts no problem, Id still uee good heavy battery starter and ground cables such as at least 1 better yet 0 or even 00 Gauge.
John T
