Dan J Benoit
Well, about 3 weeks ago I came on here not even knowing what type of tractor I have. Since then with many hours of research and much help from you guys, I have learned more about it then I ever though possible. I"ve learned that it is an 841 Powermaster, and I hope it"s alright to post this question in the N forum (You guys helped me out so much last time)
It has been converted to a 12 volt, got new plug wires, distributer cap, coil, condenser and points. I finally got it running!! My question now is about the ballast resistor:
It has a 3 inch long ceramic piece that resembles what Ive seen online being called a ballast resistor. From what I understand, it is supposed to drop the voltage from 12 to 6 volts, but when I test between the OUT pole and ground, I still get 12 volts. Is this one of those jobbies that starts working when it heats up? If that IS in fact how it works, how would I go about testing it, and should I remove the wire from the 4th post of the solenoid? Seeing as the coil would still be getting 12 volts until the resistor heats up anyway. It tests as 1.4 ohms across the posts also, and it"s not grounding out. Thanks again so much for all the help. I really appreciate it!
