Hi, i have a mf35 with perkins 3 cyl diesel, currently installing an almost 1000lbs (400kg) bush hog/ rotary cutter... My question is do you need rear ballast with this attachment as previous owner has rear tyres filled to 75%- should i drain out this water? I'm thinking that the cutter should be ballast enough.
Also what about front ballast... i'm guessing it is only dicey with rear hitch raised so not that important?.
Tractor will only be used for mowing,
Any thoughts appreciated..
