johnofnewhaven
You're ridiculous
wo is only fine if the hitch pin pivot point is located half way between the 2 u-joints.(quoted from post at 15:13:10 04/30/23) Extra u joint might make a difference on this one but I've had square balers with both types pto shaft and can't say that one was any better or worse than the other between the two and three joint shafts. My 7721 JD combine has the third u joint but I have to take it easy on left turns or it will rattle at 1000 rpm.
(quoted from post at 15:21:11 04/30/23) But the dual spindle /two gear box mower is almost twice the price , that is why you do not see as
many and 8 ft is too much for is tractor on the 3 point hitch , might could handel it in a pull type
but way over 4 thousand closer to 5 grand
