got a set of band duals from a buddy. these are co-op powr2 duals. dont have the T rail has lots of holes around the inside of the
rim. is there some sort of clamp that is used for these or do you just find a long J hook that fits and put it in whatever hole
lines up on the tractor hubs? only J hooks i have are 3/4 inch and i'm afraid if i drill them that size i wont get nuts on.
Gary
Not quite following your description. Is this what you're looking for?
no, i would call that the T bar style. the ones i have dont have the T just the like a rind welded to the rim that has probably 50 1/2 inch holes in it. i google co-op powr2 duals (says that on the rim) and only got one picture of it. it was in a set of 4 rims in this picture. almost looks like it should bolt directly to another hub but thats not the case. looks like the bolts just go through the holes in the ring and you would have infinate ways to get the bolts to line up. does that make sense?
You are missing a upside down U shape piece that has a peg that goes in those holes, it has a larger hole for the J bolts. Andy
(quoted from post at 07:24:51 04/25/16) do you have the ones people are talking about that go into these holes and hook the J bolt to? need 16. 8 for each tire.
8 per side? I would worry about the factory hubs holding up if you need that many to hold it on the tractor.
Never seen more than 6 per side used for snap-on duals, and that was with a 180HP tractor.
I was thinking about it and it does depend on how many lugs the tractor has.
The ones with 6 clamps have 12 lugs.
If your White has 8 lugs or 16 lugs, 4 isn't enough, and 6 doesn't distribute evenly around the wheel. So 8 would be the correct number.
