I don't claim to be an expert: I'm more of a circular mill guy: Between the two farms we have five circular mills (had six up until recently, but I finally decided to downsize). But we also have a Woodland band at one farm which is great when you want the recovery of a band instead of the speed of a circle. And I've been around a lot of other portable bands, and work for a company that builds much larger industrial sawmill equipment (though I'm off on parental leave right now). So while I'm definitely not the leading expert, I'd like to think I can comment with a little knowledge. A friend asked my thoughts on getting a bandmill a while ago and they were looking at a Woodland (a popular econo mill, and superb value for their price). Here was my response (for what it counts for). Note that because we're in Ontario, I primarily reference Canadian-mills as they're more readily available and a little cheaper to get due to lack of shipping fees.
Regarding your looking at a mill from Woodland: I know I'm always very critical on smaller bandmills, and to some extent still maintain this position. I will concede, however, that for the stuff you plan on cutting it's the way to go. For what my thoughts count for, here are a few of them:
One of my coworkers recently bought a Woodland to supplement his circular mill; he uses the circular for structural and high production and the band for quarter-sawing or custom 1" hardwood. Some of these notes come directly from him.
i) The Woodlands are cheap for a reason. Much (most) of the stuff they design is fab'd in China and crated back. Some larger portions of the frames are now made in Canada, but smaller weldments and castings are from China. They're built light. The steel also doesn't meet North American 44W/A36 standards. Not necessarily problematic, but you don't want to be loading hefty hardwood directly on it with a loader unless you're careful. The Woodland guys tailor their designs specifically to keep shipping weight down, to decrease import costs and make it easier to ship out. One of the reasons they're so successful is that they're able to cater to the Alaskan fly-in/fly-out crowd who require a light, modular mill.
ii) They don't like to be unsheltered: The paint quality isn't great. He mentioned this, and if you read online you see others have similar experiences. He bought his after using a friend's. He said his friend's - only two years old - works great but looks like it's sat outside for decades. If you keep under cover obviously not a problem.
iii) Blade tension, guide pressure, and set are the big things that make for accurate bandsawing. With the commercial headrigs like we build, piles of design work go into tailoring the wheels and guides to give the right pressure (pressure is not to be confused with tension) on the guides. This requirement for accuracy isn't much of a concern with hobby mills where you don't have to achieve unbelievably small variance, but it's not to be ignored: To achieve anything close to accurate results with a narrow hobby blade, a good manufacturer should sets the guide to give a goodly amount of pressure. To my knowledge, Cooks and Select are the only portable bandmills that do the guide pressure correctly (Cooks has a great video explaining it). Other mills have good-looking, solid guides, but they don't inherintly put any pressure on the blades.
I'm going to elaborate as this is such a critical point: The guide pressure is required to bias any blade wander away from the wheels and (most importantly) to stabilize the sinusoidal "whip" of the blade as it leaves the wheel. This is why the guides should be set to bias the blade off the wheels; you're effectively not giving it a chance to find its natural oscillation. Why do I harp on about this? None of this is too concerning if you're job requires rough-cut lumber. One of the selling features of portable bandmills is how good and clean the wood looks after cutting, compared to a circular mill. No argument there; it looks fantastic. If used in its rough-cut conditions this is ideal, but the oft-heard claim that band-cut wood has an inherently more accurate cut is incorrect. Surface finish is certainly much, much better, but surface accuracy is a different story. Even Woodmizer, who make some of the best portable bandmills, notes that 1/8 variation in thickness can be typical over the length of the board in some woods. A (properly aligned) circular mill, while often having a terrible finish, can't wander anywhere close to this much if the guides are set right. This is notable if you've ever planed band-cut wood on a small, micky-mouse thickness planer that can only takes small cuts. It looks beautiful - like it hardly needs planing at all, but it often takes at least 5 or 6 passes per side to get the whole surface to clean up. Whereas lumber form a circular mill might have a rougher finish, but will be much more accurate and thus clean up in only one or two passes. Don't mix up surface finish with surface accuracy.
How does this reflect on your purchase? In HP and Tension (note: tension, not pressure). Because very few manufacturers apply any guide pressure, their only way of keeping an accurate, pencil-thin kerf with no oscillation is to have some way to crank the blade tension up to extreme values (usually some sort of pirate-looking hand wheel, but in larger mills they use hydraulics). That has two negative effects. a) Taking a lot of power. b) Not allowing the blade any room to stretch as you've already stretched it to the max. Not allowing it to stretch and wrap over the crowned surface of the wheel (Woodland and some others don't crown their wheels uses a cheaper, but effective system - a rubber belt around the centre of the wheel rather than a crowned wheel) causes it to wander in the lateral direction (direction of carriage travel), be less accurate, and wear out blades much faster. What can you do, knowing all this? Not much, unless you want to spend the dough on a mill from Cooks or Select mill that actually takes this into account. All you can do is acknowledge that cheaper mills don't do a good job with their guides, and you can't skimp on the HP because of this. Go with the biggest engine available on whatever model you choose.
iv) Everyone who owns and uses a smaller bandmill regularly agrees on the same thing: You'll soon want a sharpener/setter. Don't be too concerned about blade or tooling manufacturers; lots of people assume blades are specific to mills/manufacturers, but they aren't. There are a few common progiles for your standard 1-1/4" width blades, and most sharpener/setters are available with the right stones & configuration for whatever you have.
I think Woodland is great and they're also nice, local people. As such, I think it's great to support them in any way possible and in general I'd encourage buying from them. That being said, I'd also take a look at what else is out there for other mills, not necessarily to buy instead of a Woodland, but just to get an idea on pricing and design. Don't be too caught up on service/parts; there's almost nothing special/unique about a bandmill that can't be purchased from industrial suppliers. In this area it's often assumed that there are the big mnufacturers (Norwood, Woodmizer, Baker) that cost crazy amounts of money, and then the Woodland. What people don't realize is there are tons of small companies like Woodland that build similarly priced mills, sometimes better, sometimes worse. A few manufacturers worth looking at for design aspects:
Vallee: More money than Woodland, but possibly the best bang for your buck in portable sawmills. Made in Quebec, these are the only sawmills in the under $10k region that have electronic head positioning (a big plus), Honda engines, and a very heavy frame - probably at least as good as Norwood's.
SMG Champion: Also made in Quebec, They have a few excellent features: alternator on their saws for electronic equipment, lots of motor power, 20" wheels rather than the more conventional 19" (helps a lot with stability/wander). Wickedly heavy duty clutch, Auto-positioning, &c.
Clark: Built in Lindsay, they're the choice around this area for commercial-use bandmills. Very simple, but rugged. I don't know about pricing, but probably out of your budget as they're more for full-time industrial users. I think their smallest model is probably about the equivalent of Woodland's biggest. The operation where Jim bought his planer used a mid-sized Clark mill.
Norwood: They make mills in Orillia that are at least as good as many of the Woodmizer at a much lower price. They're known for a laminated channel frame that's practically indestructible. Unfortunately the company was bought out by a large conglomerate recently and is 're-structuring'. Might be worth waiting to see how things settle before diving in with them.
Timbery: Well-made and good looking bandmills. Probably not worth looking at too much, as they don't offer anything that the other manufacturers don't, and they're made in Indiana so often priced more. I mention them as there's a distributor in Bancroft that a few years ago they had some really good, clear-out prices on slightly used models (the ones they'd take to shows). Not sure if they often have similar deals, but might be worth looking into.
