Ultradog MN
- Location
- Twin Cities
(quoted from post at 14:40:23 08/10/22) Read the description on this auction.
Funny and sad at the same time.
(quoted from post at 00:56:59 08/11/22) As a retired Shop Teacher all 5 schools I worked in had that same saw. If you lower the upper guide to right above the work piece where it belongs there is no exposed blade except in the cut. The upper guide is the guard. There are very few after market guards for a band saw.
So I find the ad rather odd.
(quoted from post at 07:51:26 08/12/22)(quoted from post at 00:56:59 08/11/22) As a retired Shop Teacher all 5 schools I worked in had that same saw. If you lower the upper guide to right above the work piece where it belongs there is no exposed blade except in the cut. The upper guide is the guard. There are very few after market guards for a band saw.
That's the problem. If you do this. If you do that. If you do a dozen other things. THEN it is safe. Miss any one thing, and someone loses a finger or worse.
