Battery cable replacement?
tomstractorsandtoys
My Deere 2510 needed new batteries and after inspection I should replace the cables as well. There are two positive cables that run up through the dash and behind the engine to the starter. They are very hard to install and route through the dash. Is it a bad idea to replace it with one heavy cable? I would use all solder on ends. My starter shop sells a positive end that has two outlets to solder the cable in so it would be all one continuous cable.I would be using 2/0 gauge cable.My shop sells welding cable that is much more flexible than regular battery cables.Or should I just use 2 cables and deal with it as you don't replace cables very often? Tom
(quoted from post at 17:19:22 05/02/19) My Deere 2510 needed new batteries and after inspection I should replace the cables as well. should I just use 2 cables and deal with it as you don't replace cables very often? Tom
The previous owner of my Massey Super 90 ditched the 2 battery system and just put in one big 12 so only 2 cables to deal with. I did the same with my 730 Case diesel. Half the problems. I've run the Massey through every cold Sask. winter and it never failed to start. I'm considering doing the same on my JD 2140 when the two 12 volts in it give out.
it?s easier to pull the floor plate off when replacing the battery cables I?ve found then they are easy as pie to route
So would you go from one battery positive to the other battery positive and then to the starter? Or come off each positive and meet at a Y which then goes to starter?
Without a doubt pull the floor plate but on a 2510 the cables go up inside the dash and through two holes in the firewall and have to make a 90 degree angle then around to the starter. It makes them rub the firewall and crammed in against the head. Not near as easy as a 3020 or 4020. Tom
I run two batteries on my 2510 gas. I run a cable from the positive on the left battery over to the positive on the right hand battery. From there I run one cable to the starter. I've run it that way for several years and my neighbor has the exact same setup for a lot longer than I have. We both use our 2510's to feed with in the winter so they have to start in the cold.
All the more reason to use 00 welding cables. On chafe points, I use 1" heater hose and zip ties around the cables.
What you're planning will work fine. If it were me, I would use 6 volt batteries in series like the late 20 series used. This simplifies the cables and makes a neater looking setup. Will be slightly lower CCA than the 2 12 volt setup but the same batteries as used in 4020 and larger tractors so will be more than sufficient for a 2510.
