So would I.(quoted from post at 17:26:30 09/11/19) I?d go double 00 if it was me
(quoted from post at 11:49:55 09/11/19) Again, it is all about the length. With short wire runs there is the rule of diminishing return when it comes to spending extra money on bigger wire. I already posted exactly what your voltage losses would be.
And yes, bigger wire always allows less loss. But when it comes to 1/10th of a volt at max starter amp draw - you many never notice the difference. 1/2 to 3/4 volt drop, yes. A "12 volt starter" is designed to spin at proper speed at 9 volts. Feed it only 8 1/2 volts and it slows down a lot. Feed it 8.9 volts instead of 9 volts when under absolute max load and you will likely never notice.
(quoted from post at 07:09:43 09/12/19)
It is getting to the point that I almost don't bother replying to these questions anymore. The guy asked a simple question and wanted honest answers. He did not ask for opinions.
