Battery Chargers
Grabatire
I've just aquired a battery charger that has settings for "conventional" or "low maintenance" batteries. What's the difference?
When installed in a vehicle, the alternator doesn't know the difference and they seem to charge OK.
If you spend enough money than the battery chargers have a regulator in them. This will prevent battery damage. With my charger I can turn it to almost any setting and when the battery is full it will shut off. What brand do you have?
Not sure what the difference might really be. I remember from trade school years ago that a maintenance free battery, when run completely dead, will take some time before it will start drawing power from the charger.
Different max voltage cut-out and different "float" voltage. The good chargers will have a dozen settings along with a battery temp sensor. Charge rate is lower at high temps and higher at low temps.
On cheap chargers, the two setting are almost meaningless, and don't have the proper rate for AGM batteries (which can be ruined pretty easy).
At room temp,
Standard lead acid battery is max charged at 14.8 volts, and then drops to 13.3.
A typical "maintenance free" with lead- calcium plates max charges at 14.3 volts and then drops to 13.2 volts.
A true lead-acid deep cycle battery max charges at
15 volts and then drops to 13.3.
A AGM type gell-cell battery only max charges at 14.1 volts and then drops to 13.5 volts.
A Ni-cad type max charges at 16 volts and then drops to 14.5 volts.
