Battery/charging system
JohnDeereB
I have a 1948 JD B it has a 12v battery using pos to ground, all of at once the battery went dead. It has a 6v gen and voltage reg I have not done anything with the wiring, the gen was checked and is putting out 10v. Any idea what is going on, tractor has been starting just fine for 6-8 months or more. Load test is good on battery. any Help with proper wiring or what could be wrong???
That 6 Volt Generator and 6 Volt Voltage Regulator (unless modified) isn't going to charge a 12 volt
battery very well.
You can EITHER go back to a 6 volt battery orrrrrrrrr leave the 12 and change to a 12 Volt Genny and 12
Volt Voltage Regulator. It must be a magneto ignition otherwise 12 volts on a non ballasted 6 volt coil
would have fried it (unless it had been modified).
For charging troubleshooting check out my Troubleshooting Procedure
John T
John Ts Charging Troubleshooting
