battery drain
cool hand
Location
SE IN
Anyone have a suggested method to locate a battery power drain (this on a 2010 Ford f-150) short of taking the truck to a Ford dealer's service department?
(quoted from post at 11:30:54 12/28/21) Anyone have a suggested method to locate a battery power drain (this on a 2010 Ford f-150) short of taking the truck to a Ford dealer's service department?
My FIRST guess would be the switches in the door latches, they get dust and road salt in them and "leak" enough current to trigger electronics that drain the battery.
(There are no "pin switches" in the door jambs, the switches are in the actual door latch.)
You'll need a milli amp meter and a jumper wire.
Be sure everything is off, doors closed, key removed. If there is an under-hood light, disable it.
Remove the negative battery cable. Connect the cable back to the battery with the jumper wire, wait about 5 minutes or so.
Connect the milli amp meter leads between the battery and the removed cable, just like the jumper. Remove the jumper WITHOUT BREAKING THE CONNECTION through the amp meter. If connection is broken or even if you think it may have broken, replace the jumper and let it sit another 5 minutes. Be sure the meter is set correctly, and the leads are in the proper configuration. You can't make adjustments once the test is underway.
Take the amp reading. 20 milliamps is great, up to 100 is not that great but acceptable. Over that, there is a problem.
An easy way is to do it in steps. First step is to look at all the lights and accessories to be sure they are off.
Next: remove the positive battery terminal and put the leads to an amp meter on the post and on the terminal you removed. Many Multi Meters have 10 amp rated settings, usually requiring putting the leads or one lead in a different socket in the meter. The normal draw is less than 150 milliamps. If more like 300+ ma. it will drain the battery in a week or so.
Next pull fuses one at a time while watching the meter. (the first attachment of the meter could draw more, but in 2 or 3 seconds, it should be at or below 150ma). Always put fuses back into the block as soon as it is pulled so they stay organized. The radio fuse will lower the reading some due to the drain of keeping the station presets. There are heavy fuses that protect the alternator and possibly the air conditioner system that are different size, and possibly under the hood. When the amp draw drops to at or below the 150ma range, you found the circuit. Then tracing that to its end use, and disconnecting it there can determine if the issue is in those wires, or the device. A test light can be used in stead of a meter, it might be easier to see when pulling fuses. Jim
Take the negative battery cable off.
Put a test light between the cable and battery post.
If the light comes on you have a drain.
The brighter the light the more the drain.
Now start taking fuses out.
When the light goes off you found the circuit the drain is in.
My Neighbour Lady had purchased a new 1998 Lincoln .
The vehicles battery was going dead....
Before she returned it to the dealer, I was asked to diagnose the DRAIN...as the dealer ship was treating her as a dumb Blonde...
With a battery cable disconnected and a voltmeter installed....
We started to remove and replace one FUSE at a time.....
When a specific fuse was removed we lost a reading on the VOLTMETER we drove her car to a dealer.
I explained exactly where the fuse was that curtailed any battery draw...
NOW..The dealer demanded my credentials so as to prove I was an idiot!
I left.... the Neighbour Lady...she ripped a new aarrrss in the Shop Workorder Writer...
She had her car returned with an apology...
Bob..
Long story, I will try to shorten it up. 2014 Ford F150 Super Cab with eco boost engine approximately 95000 mi when trouble started a year ago. With battery connected I had an intermittent drain that would drain battery in 2 days. Disconnected battery and charged fully and let sit 4 days no discharge. it was a battery less than a year old at the time. took to my mechanic he saw a code for BCM bad and said dealer would have to replace it as it required programing when replaced. took to dealer told them what he said, they let it set and was drained fully. got it into their shop and checked it out said battery was bad. got battery replaced under warranty problem went away UNTIL LAST MONTH. After looking on the internet found several sites that said Ford had a problem with the rear window deicer, to remove the fuse ( I do not use it much anyway) it was fuse 32 on my truck. I was still having a problem so I left the fuse out and disconnected the Battery Saver sensor, and I have not had the problem since. I was getting a error on my radio screen that said Battery saver, start engine or turn ignition off Funny thing was I got that message with the KEYS IN MY HAND. So it seemed to me that it was a common problem with my truck but I don't know if it would be the same on your year truck. Try Googling it with as much specific information as you can, model, year, engine, milage and see what you get.
Cool hand,
For those out there that seem to think you can diagnose this, well, here's a twist.
Some vehicles use a radio frequency signal to allow door lock/open operations.
Park near an airport and some vehicles will keep certain circuits 'active, which can/will drain the battery. I believe Volvo is one of them that were recalled.
D.
I had the same problem with a 2000 Lincoln, I assume it was a LS series but have forgotten, anyway it was the one with the Jaguar engine. Has it at dealer several days and a bit of a bill, so i took it to another dealer and traded it in. in 2013 I dought a Lincoln MKZ and had same problem. I raised enough fuss with the dealer and then they put in new alternator battery and Same problem, then started taking key out of switch and no problem.
(quoted from post at 14:22:36 12/28/21) Cool hand,
D.
Dennis, it looks to me like four guys have given very good diagnosis advise. It does not look like "seem to think" to me.
I had the same problem on a '99 grand Cherokee. I did the same thing as Moonlite, I was to cheap and lazy to try and figure it out. Also I get a brain drain when it comes to electrical problems on vehicles.
showcrop,
I did not mean that the advice here was misguided. I was trying to propose that some items require even more thinking.
I agree with the ammeter approach, or light bulb, and subsequent fuse removal.
It is where I would start. What I tried, and likely failed to say was there are some unseen items that need consideration.
No hurt feeling here,
D.
The problem with using dealerships for non warranty diagnostic work is it puts the mechanic on the hour where he makes somewhere between 1/4 to 1/2 what he makes when working on flat rate. The best mechanics are usually the highest seniority and refuse the work so it goes to the shop newbie who is non too happy about being on the hour and is the least knowledgeable in the shop,, need I say more?
If you can't find it yourself check around for a good independant shop.
A quick check for a common issue is to disconnect the alternator, if the drain goes away replace it.
Had a friend who's mini-van battery would go dead over night. After poking around, with help of others, discovered some junk in the van that was pressing on the seat adjust switch, and the motor was dead-headed, draining the battery.
Gotta narrow down the circuit that it's in, thus, the fuse removal project.
Good luck !
You have to do EXACTLY as Janicholson says; that is the correct procedure. And also what he says about the 3 second delay after the initial hook up of the amp/multimeter leads; that is the draw of all the modules before they go to sleep. I would even wait longer than 5 seconds. When I would check a semi tractor, you could see each module's draw before they went to sleep, one by one, and the amp draw would drop out. Usually a draw of less than .5amp will not kill a good battery. When you find the circuit that has a high draw that does not drop out, you found your problem. Mark.
We had a 97 Grand Cherokee that would drain a battery overnight....sometimes. It could go for months without a pro then do it two or three times in a row. I finally traced it down to the fuse for the interior light circuit. That was controlled by the body control module. I just left the fuse out. My grandson is having the same problem with his 05 Chevy pickup. I helped him check it out last week. It draws .85 amps that drops to .45 with the info center fuse out. Beyond me at that point.
