Battery Maintainer
A battery maintainer won't be enough for recharging a golf cart.
You need the real deal, high amp charger to keep it charged.
Maintainers only produce about .75 amp, even if you put a maintainer on each battery, it would take a long time, days, weeks, to bring them back up.
I have a 36v charger but my problem is when I leave FL. for MI. for seven months the voltage will sometimes drop down below 28v and the 36v charger will not come on below 28 volts.So I then have to put my 12volt charger on two 6 volt battery's in series until the voltage is over 28v. If I had a 36v maintainer I could hook up for the seven months I'm gone would make life much easier.
Thanks for your reply.
