jniolon
old and in the way
I've got two of these and keep one on my hobby truck battery to keep it topped off
After a drive yesterday I hooked it up (with a voltmeter attached) and it shows zero output. Took it to the bench and tested...same results.
I keep a spare and tried it and it's dead too ??"??? tried two different meters, checked for ac at the outlet 120 volt there... checked the meters on another battery and they work...
checked continuity across primary 3 ohms secondary 43 ohms and both leads show continuity from case to connector at the the of the wire I'm baffled
odd that two would die together...Battery charger gurus !!! anything serviceable inside ?? we've had a couple of power outages lately but can't see that killing a transformer...ideas??
thanks
john
This post was edited by jniolon on 07/27/2022 at 02:38 pm.
thanks
john
