Be it ever so humble....
kcm.MN
Location
NW Minnesota
Puzzle: https://jigex.com/pGQnU
I'm guessing those diagonal boards added a good deal of strength to the structure and kept the house square. I think this was brilliant of that builder. The old house still stands straight and tall.
(quoted from post at 23:09:59 10/14/21) I'm guessing those diagonal boards added a good deal of strength to the structure and kept the house square. I think this was brilliant of that builder. The old house still stands straight and tall.
The diagonal boards were for wind bracing. Plywood made it unnecessary. I think that it was a lot more common to notch the studs and put two diagonal 2x4s in each corner.
Always seemed strange they went to great extent to make the building rigid and heavy, but would short cut the foundation, build them down in the dirt and use wood piers.
Guess you had to make do with what you had!
Looks like South Dakota, West of the Missouri, or Moosejaw, Saskatchewan, or points in between.
Reminds me of the movie Days of Heaven.
Prairie wind? I'll say the front door faces east. Wood was plentiful, makes you wonder what the cost? Where
it came from they probably cut it to get it out of the way. That's a fine house, maybe Thee House as Harold
Stokes said. I haven't run across diagonal sheathing like that. It makes sense that it was for the wind. The
build out over the open window, I wonder could you mount a pulley off of it to pull things up? Slate for
shingles? Nice Kcm, this gives a round barn a run. It is up close though.
