Behlen Overdrive on JD B
I am putting an overdrive on a 37 B. On the countershaft it appears that there should be a snap ring between the idle gear and the spacer next to the second/fourth gear. There is a groove for one. On the original shaft there is a collar there. But there can not be a collar on this longer shaft because it has to be installed through the side, not the top. Can anyone help?
