Of course the post below on Bifocals has prompted me to post this. I've been wanting to post this for a while anyway.
I think the one test they do at the eye doctor is so obsolete. It's the one where you sit down and the nurse sits across from you and tells you to stare at her nose so she can mark the lenses where your bifocal should be located in the lense. This is all based on how tall or short the nurse or patient ratio is. A taller nurse will cause your bifocal to be higher on the lense as opposed to a shorter nurse. They use a machine to measure the distance between your two pupils so why not have a machine to measure for the position of the bifocal area?? I found my bifocals were too low so the next time I got new glasses the nurse said to look at the tip of her nose, so I stared at her forehead. This raised the bifocal in the lense and it made a big difference since most of my work is close up. I don't need to tilt my had back to focus now. Tricks of the trade I guess you can call it. I am going to mention this to the staff next month when I get my annual checkup.
