Belarus 611
ldinpei
I just got a Belarus 611 that sat around for a few years, and I got it running and it seems to run reasonably well. The issue I'm having is that I have no power steering. It has fully hydrostatic steering. All other hydraulics work well. Does anyone have experience with this? I assume that the front pump is for steering, and I suspect it is done. does anyone know specs for this pump so I can test it before I order one?
TIA
I have no experience with the Belarus 611:
I have operated the Belarus 400 series hundreds of Hrs. The pump in question had a LEVER so as to engage and disengage the pump drive.
Lever was attached to pump: Pump was at the front of the Engine block,upper left side,viewing engine as from the operator seat.
Bob...Owner operator Belarus 400 series tractor.
Yes, this tractor has this lever as well, i assume to help with cold weather starting. It works as it should. The only way I can make it steer right without moving is to lift the front end up with the loader. Seems like it will steer left much easier than right.
So I went ahead and ordered a new steering pump, and installed it last night. I was having to keep adding hydraulic oil, because the loader would stop working. So I decided I better check the engine oil level in case it was going in there, and the engine oil was full of hydraulic oil right to the dipstick hole. I realize that it had to come from the seal in either the steering pump or the main pump, but I'm stumped as to why. Does anybody have any experience with this? Could there be something in the steering motor causing a dead head situation? I suspect its the steering pump because the loader would operate as long as there was enough oil in the tank, however, the steering still was not working.
I'm planning on pulling the steering pump out this evening, but just curious as to weather someone can offer insight in the meantime.
Thanks.
