Belarus FWA troubles
safetystu
Hello everyone, I have an old Belarus FWA tractor, never was able to nail down a model or year. (I was told it was an '82 when I purchased it.) If I remember right, they are not very popular here? I was using it today, heard and felt a bang form the front end. Left front tire froze. I took a brief look and couldn't se anything wrong. When I tried to move the tractor, it worked again, got it back to it's parking spot. More investigation showed that it looks like a blew some sort of seal around the top of the wheel assembly. Pictures to follow if I can figure out how to post them. Any help will be appreciated.
:lol: Well, at least I have a mask, thanks to present conditions. I will start the surgery tomorrow, not looking forward to what I may find, probably be posting more photo's looking for diagnostics from the group.... :?
looks interesting..do you have a model number, its not a 420, guessing a 500 or 800 series, or a newer 52 series? engine model number could be helpful, that will help you to find parts and the Belarus web site for info.
I would guess that a tooth has broken off the bevel gears and has forced the housing apart, possibly shearing a retaining assembly also on the bottom that holds all together?
The broken piece may of dropped out of the mesh area and allows gears to rotate now
Look at getting a new set of seals, rotating/thrush bearing, maybe a gear or gear set, hopefully the casting itself is not cracked.
A possible source of parts in Canada is " Fawcett Tractor Salvage" web site/phone number, located in Ontario.
Best guess and hope it helps.
PS: check the oil levels in the final drives also.....since its apart.
They always seep around the top like that. There's a spring in there and that unit travels up and down, and the o rings leak.
Sounds like you broke a gear in there, not hard to fix. Pull that wheel, and you'll see a ring of bolts around the carrier. Take them out, and there's a couple of draw bolt holes that you put a bolt in and tighten them, it will separate the case. Pull it out, you'll be able to find your problem most likely. Belarus in Milwaukee will have the parts you need, just rebuilt one of mine on my 820.Belarus's number is 1 800 356 2336
Is your tractor air cooled or water cooled? If it's air cooled it's a 400 series, water cooled, 500-900 series.
Sounds easy, LOL, I am far from a mechanic. I hope you are right and it's a simple fix and not too costly. Thanks very much for the phone number, I have had some luck finding parts for this old girl, however, it's always been a process...
Thank you for the reply, it is water cooled, I think it may be an 800 series, every other time I try to research it, I am told to look for serial numbers that seem to be missing.
Thanks for the tip, had a quick look. Those will help a lot. I had taken a look last year for videos on Belarus repairs and found almost nothing. I wouldn't have tried again if you didn't suggest it!
