It is easier to keep a LONG belt tight and transmitting power without slipping than it is with a short one.Most of the tractor belt run implement belts are very long. Is there a reason for this?
Agree. And there is more room around the driven equipment, it stays cooler in operation, as well as it looks cool. JimIt is easier to keep a LONG belt tight and transmitting power without slipping than it is with a short one.
The suspended weight of the long belt is the big factor in this, IMHO.
A couple observations. Have heard said about the proximity of the steam engine to the straw pile, but this doesn’t always hold water as sparks can be cast by the wind. Most likely that a long belt is heavy and can transmit driven power being looser than a short belt thereby lessening the wear on bearings versus a short tight belt.Most of the tractor belt run implement belts are very long. Is there a reason for this?
You talking about the belt or the implement itself? Any examples?Most of the tractor belt run implement belts are very long. Is there a reason for this?
In addition to the other answers, the weight of the belt in motion is a source of kinetic energy in the belt. An example of how this plays out is a hammer mill. You get the tractor up to speed, and the belt in motion at a good clip, throw a bunch of whatever into the mill and depending on the amount of energy in the belt, determines how fast it will digest that wad of whatever and be ready for the next load.Most of the tractor belt run implement belts are very long. Is there a reason for this?
I remember reading that HD used that firing pattern before the Waterloo tractors which was the basis of what JD did from 1918-1960.I can't imagine trying to run a sawmill with a Johnny Popper, big flywheel or not. Course as I understood the popper, the flywheel on the tractor did the work, the pop-pop-rest, etc., etc., was just to get and keep the flywheel turning.
On the pop-pop subject, anybody know why the original Harley designers decided to use the same analogy on their cycles? I never saw the size of the flywheel on one but there isn't all that much room like on a tractor.
Really? So did the HD have a pretty good sized flywheel? Otherwise what was the point in the timing sequence it used that differed from every other internal combustion engine (of which I am aware) at the time?I remember reading that HD used that firing pattern before the Waterloo tractors which was the basis of what JD did from 1918-1960.
Don't have an answer for you.Really? So did the HD have a pretty good sized flywheel? Otherwise what was the point in the timing sequence it used that differed from every other internal combustion engine (of which I am aware) at the time?
Avoiding patents would be my guess.Really? So did the HD have a pretty good sized flywheel? Otherwise what was the point in the timing sequence it used that differed from every other internal combustion engine (of which I am aware) at the time?
Flywheels (there are two, one on each side of the rod) are about 13 inches) in diameter. One body has ever accused a HD of being smooth. there is a reason they are called the Milwaukee Vibrator, and the engine is now floats in rubber.Really? So did the HD have a pretty good sized flywheel? Otherwise what was the point in the timing sequence it used that differed from every other internal combustion engine (of which I am aware) at the time?
The rasher was gone about time I came along, 2 or 3 years old and back in the mid 40's. I have ran belt powered cordwood (Buzz) saw and corn shreader and hammer mill and used same about 25 foot between tractor pully and implement pulley using same 6 inch wide belt. Now the 3 pt mounted saw was about 4-5 foot long. The thrashers were powered with an 8 inch wide belt, not 6 inch like other implements and took more power so larger belt to power would make sence. But I think, have no prof of what I think but location was problaby the most inportant thing in determining belt length The corn shreader was used until 1960 and the hammer mill until 1980 for cow feed. Saw later for fire wood.Old guy I helped years ago used the same belt on his silo blower as he did on the buzz saw, as far as I can remember. He gave up the thresher years before that, so I can't comment on what belt he used on that.
