Bendix carb running lean
Are you running a fuel pump? If so, the bowl vent in the carb is probably plugged or restricted. You need to send the carb out for a rebuild that will actually get all of the passages in the carb clean. For this, I suggest that you contact Motec Engineering at 765 - nine six three - 66 two eight. You will want to speak with Matt.
Regards,
Goldsburg
