Kenockee 8N
So I am not quite sure when I did it but when I switched from the draw bar to my back blade, I noticed that my left hand lower lift arm is bent. First off, I see that there are "weld on" replacement ends. I'm not quite sure if they are long enough to get rid of the bend or if I should just get a new lift arm.
If I get a new lift arm, I've seen that some replacements are better than others. Which replacement is the best to get?
Am I opening Pandora's box by trying to remove the lower lift arm and having to remove the left trumpet if the nut spins and can't remove it?
