bigger wheels tea20
Your rear tires are 13.6-28 on a 12" wide rim.
Now to answer what size front tires you have as John Deere D asked. Like the rear tires there as the size number, besides the diameter. a 6.00-16 is smaller than a 7.50-16. Again, rim width can control the tire that fits correctly.
Take note of my post on June 6, 2026.......
Take note of Jim.ME. post on June,21,2026....
My fronts are 16 in x 6 in wide. The tires are old and writing worn off.
The Ferguson TEA-20's that arrived (from Coventry England) in my area (North western Alberta Canada) ran 10 X 28" REAR TIRES......
Front were 4 X 19" Tires.
As the above sizes are no longer readily available.........
Pic is of my Ferguson TEA-20 with 12.4 X 28 Rears
4.00 X 19 Fronts
You can see the front end is lower........
Your TEA-20 FRONT HUB is the same as my MF 35.........
Your FRONT HUB has strength Gussets cast into the front Hubs.
NON of my parts TEA-20s or my daily user has GUSSETS Cast into the front HUBS.
NOTE
The entire front SPINDLES from a TEA-20 are a direct fit onto my MF 35 Manufactured in England.
I had a front spindle on my MF 35 fail, due to to much weight on the front AXEL,.....LOADER now removed
Bob...
4.00 X 19 Fronts
NOTE
Bob...
So,do i have a tea 20 / 30 tractor? I believe it's a combination of a couple tractors
Yes I believe your Tractor is fabrication of several Tractors.
The Part #'s for the TEA-20...front Spindles / Hub assembles are a DIFFERENT part # than the MF 35....However,the MF 35 and the TEA-20 Spindles /Hub assembles are a direct fit.
I can verify the above as I own a daily user user "TEA-20" as well as a "MF 35".
The front left Spindle / Hub assembly on my MF35 is from one of my TEA-20 parts Tractors.
