Billy Shafer onan generator update
Billy did as you said and added a 12 ft extension to the power leads and was able to finally get a frequency reading. Got it adjusted and give it a extended run. One problem is coming up sometimes it starts and dies - if you hold the start button it will continue to run, the ac light isn't on when this happens. Wait a few seconds and retry and and it will usually start will all lights working.
I will test the oil pressure switch and check the oil pressure with a gauge tomorrow and see if that's the problem.
You also need to check the brushes. In the gen section. They are under a black plastic cover that is facing out. Make sure they are free in the guides. Slip rings may also need to be cleaned.
I checked the brushes and cleaned up the slip rings before I did anything. Checked oil pressure today has 30psi and bypassed the switch and it still has the same problem. It will start and continue to run after 2 or 3 tries. The generator only has 338 hours.
