bleeding hyd sytem on 44 special
keith tack
hello! I'm new to the tractor world(dumb)and sure could use some advice. I changed the rotting hoses that go to the pull behind cylinder of my 1954 Massey-Harris 44 special. Now, I don't know what the proper procedure is for bleeding the system. It worked just fine before changing the hoses. The only thing the manual shows is a bleed plug on the hydraulic oil filter.Does anyone know the correct procedure? Can anyone out there help me?
I need to get my deer plot planted. Thank you in advance. Keith
Just cycle the cylinder until it works right. Might take a few cycles before you get all the air out. It works better if there is some resistance on the cylinder
