Bleeding Hydraulic Cylinders for Front-End Loader
MikeyK
Hi,
I just rebuilt the hydraulic cylinders for the front-end loader on my Ford 860. These are single-acting cylinders without bleeder screws. When mounted, the cylinders are always angled upward. Once I get the cylinders remounted and the hydraulic lines connected, how do I bleed air out of the cylinders?
I read that, in some systems, the air will get trapped as small bubbles in the fluid and self-purge when returned to the sump. I also read that, in some cases, any excess air will escape past the gland seals, without any damage.
I just wanted to double-check so I don't end up ruining the new seals I just installed. Thanks!
-Mike
I've never had a problem with air in the cylinders I've rebuilt,I cycle the cylinder several times thru it's full travel and the air in the cylinder works it's
way out thru the return hose.
If you hook up the line when the cylinder is retracted then there shouldn't be much air to need purging. A small amount of air shouldn't be a problem. It will either wok its way out eventually or it will stay in the cylinder and create a small pocket that gets compressed to almost nothing in size at the beginning of the stroke each time that you raise the arms. I doubt that it would be enough to even notice a delay when when starting to raise from fully down.
