petectid-HT
I won't go into the issues I'm having with this person, but they decided that they would put water into my fuel tank. I've emptied this and bleed the lines through to the bleed screw on the fuel pump, realising that I had started the tractor and that it suddenly cut out on me after a short time I now have the contaminated fuel in the fuel pump and the three feeds to the injectors. I disconected the injecter feeds and cranked the engine over with the starter and I am getting the contaminated fuel at the injectors. The flow here seems very small it just spits a small amount of fuel out at each timing does that sound correct or should it be a large flow of fuel. Is there a way of clearing the contamination from the fuel pump and lines to the injectors other than running the battery flat in short bursts? My tractor is a Yanmar 3110D I may need to tow the tractor, do the breaks work when the engine is not running? Would need to tow down a hill, would that be okay?
