Block boring - JD A
MTB
I am rebuilding my grandpa's 1948 JD A and the cylinder block is rust pitted. I am looking for a source who can bore the A3462R cylinder block, preferably in North Dakota. Also may be interested in a usable used block/pistons.
I sent you an email about boring your block. We can do it for you by Sioux Falls, SD.
I had my G block bored, and dry sleeved, then bored to .125 over, in Sioux Falls quite a number of years ago, but I don't remember the name of the place.
Ask at the NAPA store in Jamestown. There is a machine shop on the south side of town, Dakota Engine Builders, 2809 Hwy 281 S.,701-252-2344. If not Hedahls in Aberdeen,SD.
If the top surface of the block is still in good shape I'd try and find a place that can do the boring without removing the studs ! I had some shops ruin a block removing the studs.
I found a place that does semi truck engines that has large enough equipment to bore them.
