Has anyone ever seen a block crack on the verticle piece of metal that is between the 2 side covers that cover the valve springs on the engine. It is all the way through. I can"t see were it would case any real problems other than a slight oil leak and what is one more. I do not know how long it has been like this. I was just going to use some silicone when I put the side covers back on to try to minimize the leak,. This is on a 1941 9n, that has been running fine. I just needed to replace the manifold and thought while I had that off I would fix the side cover leak. By the way they were leaking from the bottom. That is when I saw this crack. Any thoughts from anyone, repair advice. Thank you in advance.
