Block Crack Repair - Any Worry?
alek9997
First of all I am no authority of engine block repair (Cracks, etc). Recently I came across a Farmall H for sale that apparently ran a couple years back. The owner according to neighbors is away for a while and anyone interested in the tractor is to ask them about it.
Anyway, the tractor upon inspection appears to be mostly good condition, no evident bad leaks, rust, or anything of that nature. Still has 6V system. But my biggest concern is on the left-hand side of the engine block. As you can see it has some sort of repair done to it. I believe from the sounds of it the repair was done BEFORE the current owner of the tractor, who has as I said run it fairly recently.
Is this a reason to be concerned or to move on to look for something better? Anyone here regularly or semi-regularly operate tractors with similar repair done to the block? I know none of this is of much help, and I will try to get more information on the repair as soon as I can.
Would help if I uploaded the photos.
If it dont leak or seep,dont worry.A lot of those old Farmalls were cracked and repaired there.Fairly common.My uncle has an M that's been cracked/repaired for 60+ years
looks like a good repair to me. No leaks. I would be more worried about how long he has been running the tractor without the air cleaner hooked up. Jim.
Overhauled a 340 IH in FFA shop class in 1983 that had a crack in the block. Shop teacher had me clean it good and use silicon sealer....I didn't know any better and went ahead and did it, and it ran for 10 years after that before we sold the tractor without a leak, and as far as I know is still running fine. Repaired one on a 450 Farmall with JB Weld a few years back, and it's never seeped a bit. Pretty common deal on older tractors...most F-20 blocks I've seen have been repaired as well, although usually bronzed.
