Bob Bancroft
NY 986
You had mentioned owning a JD disk at one time. Just wondering as to the model and how it was for you? There might be a JD disk coming up for sale nearby but I don't know the model number at this point in time.
Over the years a lot of tractors of all colors pulled Green planters, because whatever your loyalty was the green planters were just better.
I say that, because in the same neighborhood, a lot of tractors of all colors pulled Red disks, because - Red disks are just better.
Any disk will get some ground worked up, but the JD models seem to ridge and just not quite as good as similar aged IHC disks.
My two cents.
Paul
While IH disks are good they are a ways from being perfect. Around here there are not many IH disks never mind IH disks for sale. That aside we have to have a cultipacker in back of the disk to make things level for soybeans so if the JD does not do a perfect job the cultipacker will cover up its sins. Lastly, this disk might be available at a good price which is very important right now. Also, I have three JD locations within a half an hour of me and two deliver to my farm. Case IH is further and does not always deliver the same day as the order goes in.
My disc history.
Had an AC, maybe 2300? 13' Was a good disc. Traded it for an Athens 15'. That was a good disc. Moved up to a used 26' JD. I can't remember the model. It looked like new, and did a very good job. But the bearings started going. That was the weak spot. They were nothing more than a standard "greasable" ball bearing in flangettes. {Which seldom take grease like they're supposed to] Based on my good experience with the Athens, the JD was traded for a new 26' Athens, w/baskets. That was a good disc, except for a major flaw. The leveling mechanism was no heavier than it was on the 15'. They replaced it after it folded in half. I was scared of it. I looked at CaseIH "turbo till", and Landoll "VT". I went with the Landoll. This should last me!
Flangette type bearings are what I have in the White disk that I am using at present. Durability is an issue and I am in my 50's so I don't move as fast to change the bearings and it is harder to wrestle with. It's also not immune to broken gang bolts if an unexpected rock is close to the surface. It was not so bothersome years ago but the springs have been short lately so I would like something more durable in general.
I grew up with the green, every implement on the farm was green and our disk was a 14' RW. It lasted many years and did a reasonable job. When it came time to get a bigger disk I bought a new 21' Case disk with 9" blade spacing in 1975. I forget the model but it was manual fold, stick the pins through the hinge joint and it was rigid. The Case disk did a really good job for me for 30 years and many thousands of acres. Yes I had to replace bearings and blades every so often but the overall job it did was reasonably flat. I was the only owner of a Case disk for many miles around but that was OK, the disk earned it's keep. The frame started cracking and it was time for blades and bearings so I junked it out and replaced it with a 21' 230 Deere disk. I haven't used the Deere disk for several years but when I did use it I swore I would never use it again because of the ridging in the center.
I would like to no till but for various reasons I can not for the near future. I think the 1970's Case disks were made by AMCO which I thought were a pretty good disk.
The disk that was mentioned to me is suppose to be of the 63X family but I won't know for sure for a few days.
All of these discs have been the "rock flex" type. No problems other than what I mentioned. I talked to the guy who sold me the JD disc and he thought it was a 63something? At 65+, and working alone, I'm done with heavy repairs.
Dad and I had a Kewanee flat fold disk bought new in 1976. Ridged and was a rock magnet. Get rock between blades and it would catch on standard and stop that gang. Traded that off and bought black gang JD 230 disk. I thought it did good job but the bolts holding standards to rectangular tube would first stretch than come loose. More than once brought it home with chain holding gang up. Since 1996 have Krause rock flex disk. Better than my previous disks. Dad always said you should have field cultivator small enough to pull at 6 mph even if you do not go that fast and disk big enough so operator cannot pull too fast or deep.
We have an old JD disc with practically new blades we use for the garden in 12 foot. You have to set the notches in the tongue for depth. No transport wheels on it. Was here when I was a little kid so must be all of 60 years old or more. Then got an IH 470 with the spring loaded wing gangs worked good and was level behind. Now have a 30 ft Sunflower and that is the berries for working ground. I dug up a 40 year old pasture with it and worked down to plant corn on it. Made a nice seedbed in a few passes. This was where the wagon got parked to feed hay in during the year so all kinds of ruts cattle foot ruts along side of the wagon and so forth. will probably do the same thing with it this spring with corn again on it. Then beans with alfalfa for the rest of my life. Really to hilly to want to plant even with no thrill.
