KJS
Need to rebuild a Wisconsin VH4D engine in the 600 bobcat I have. Engine was rebuilt last year but the crankshaft broke recently. Possible cause could have been when it was welded up.
the specs I need are the fallowing:
Crankshaft end play
connecting rod bolt torque
head bolt torque
crankshaft end play .002-.004
connecting rod bolt torque 22-28 ft lbs
head bolt torque 22-24 ft lbs
The 600 Bobcat came with a VF4D engine rated at 25 horsepower
The 610 Bobcat came with a VH4D engine rated at 30 horsepower.
the information that you have requested is the same for both engines..
However::
the ignition timing on the VF4D is 27 degrees before TDC
the ignition timing on the VH4D is 23 degrees before TDC
(quoted from post at 19:00:17 11/25/09) crankshaft end play .002-.004
However::
Connecting rod bolt torque is listed as 20-28 foot pounds
