Bobcat Clark melroe 730
CLM66
I'm needing pictures of different drive couplings for my bobcat, it is a double ujoint type with I'm guessing slip yoke type. Thanks
I would suggest you talk to a Bobcat dealer. I seem to remember they had production changes during model runs, so I believe you will need your serial number as well. Bobcat has some parts manuals on line you can use, and they reference serial numbers.
Ok thanks, the service manual, doesn't even show or cover much of engine drive couplings trying to
remove mine but is stuck will not separate from pump.
(quoted from post at 09:43:50 02/05/21) Ok thanks, the service manual, doesn't even show or cover much of engine drive couplings trying to
Not surprising that a service manual doesn't say do this if it is stuck. They figure the mechanic will handle that, if it is stuck which they don't expect it to be, just like removing broken bolts and such.
