bobcat excavator control panel
Not sure where to post this. A friend dropped off a mid size excavator at the farm last week for me to use for a while. There are about a dozen squares that
light up when I start it and they all go out except one. This square has a picture of a track at the bottom with a picture of the battery in the upper left
and an open padlock in the upper right. It is the only one that stays lit. It isn't a bad battery because it starts well. Hoping someone can help me.
Thanks, Ellis
When I have a problem like this. I will usually call the owner of the equipment. than I will explain that I will find and fix this problem. I will also tell them that if I break it worse well than I have done my part in trying to fix it. this always works they come out fast and they will fix it why because they do not want me to break it any worse than what it is. Trust me it works.
(quoted from post at 10:13:39 08/15/21) Not sure where to post this. A friend dropped off a mid size excavator at the farm last week for me to use for a while. There are about a dozen squares that
Thanks, Ellis
Mid size bobcat excavator? Different models could have different panels. Does it go out when you lift the left arm rest with the engine running? It may be telling you travel and other functions are unlocked and live. Why not just ask your friend who dropped it off for you? If its not his, ask the owner, someone already familiar with it likely already knows. Most of them had a copy of the Operator's Manual in the cab, unless someone took it.
HUMMMMM , sounds like and old friend of mine . Called him one day and asked if he had one of his 750 John Deere dozers that i could use for a few days as he had 4 of them plus the 4 850 plus the 4 D 6D's and i get ah yea sure BUT you will have to go pick it up , fine wheres it at and he tells me . OK fine . He tells me that the one low boy was setting with the dozer all i needed was my semi. tractor . Just a little jont up the road 57 miles away . I get there and the lowboy is not blocked up and layen on the ground , fine easy problem to fix . Get hooked up loaded up chained down and off . I get down to the farm and start working and made like three passes down into the clay and as i was backing up i can now see this trail of RED fluid leaking out from under the right side under the machine . Great now what . I stop and shut down and start looking . Drop the right hand hen hole cover and i have hydrastatic fluid leaking off the right hydrastatic motor . Ah nothing like pulling a hydrastatic motor out of a 750 Deere Major tear down three days worth of work . That night it happened he calls me and say oh i forgot to tell you to keep and eye on the hydrastatic fluid as it has been leaking a LITTLE , A LITTLE i made three passes and i was about out and OH BTW the right track motor is setting on the ground . Chase parts buy 55 gallon of HY Stat fluid fix leak put motor back in , have deere come down and reset the settings . when done i could have paid someone to do the job for less. Borrow his Deere 410 hoe no lights and no charge have to fix before use .
Just looking briefly at an online manual that appears to be for a Bobcat mini-excavator it looks like that symbol is telling you a function is active as others have said. In other words ..expect a movement or action response from the machine if the controls are moved. Again looking BRIEFLY if there is a problem there will be a beeper along with a flashing light. Use this info at your own risk. Best to find the operators manual for the model of the machine you are using to get a positive answer.
