Cockbird_Hunter
I just completed surface preparation/priming of a tractor nose cone with the following procedure:
A. Applied 2 coats of PPG MP170 epoxy primer over bare metal.
B. Applied 4 coats PPB MP182 2K surfacer over the epoxy primer.
After priming, I noticed a couple of small dings I missed in my initial surface prep. of body filler on the bare metal. I have done no sanding to the MP182 yet....
My question is can I apply body filler (fiberglass + resin mix) onto the MP182....possibly scuffing first with 80 grit sandpaper and get good adhesion of the body filler? Typically in the past I have only applied body filler directly onto bare metal scuffed w/ 80 grit & have had good results.
I"m assuming the next step after applying the body filler (if recommended) would to be sand 220, followed by 400 grit the entire surface & reapply 3-4 coats MP182 then sand 220/400 grit again. I am planning to topcoat w/ PPG MTK single stage urethane.
