Bolt Pattern for C-169 vs C-153
Bullet23
Does anyone know the bolt pattern for a International C-169 engine. We got a 63' International 2504 with a C-153 that spun a bearing and through a connecting rod. I've seen posts where people have mentioned the back of the block is the same between a C-153 and a C-169. Essentially trying to swap in a C-169 in place of a C-153 can it be done?
We have the C-153 that has the angular style with the starter assembly located within the main body of the tractor when you split it. See picture
If anyone has a picture the back of a C-169 that would be awesome or has heard of people swapping a C-153 for a c-169.
Clutch housing the engines bolt to is the same size and it can be made to bolt up but a whole bunch of modifications after that.
Then you have the difference in RPM between the engines, meaning a c-169 will need turned up some to get the PTO and hydraulic pump
in range.
