perryjosh64
Folks I posted this in general forum already but thought I try here to. Replacing water pump on 64 Ford 2000 tractor. My I&T Ford shop manual FO-20 says torque the "retaining cap screws" to 25-35 ft-lb. Bolts are 5/16-18 1-1/4in long. Already broke a 5/16 bolt replacing the thermostat but used old bolt putting it end so just assumed bolt was old/damaged so just got new grade 5 bolts for both thermostat and water pump. However when I looked up torque specs for both grade 5 multiple sources showed 157-209 in-lb (13-17 ft-lb) and 221-295 in-lb (18-24 ft-lb) for grade 8. I have another manual (Ford Tractor shop manual 1955-1960) that says 10-15 ft-lb for water pump. Any idea why the big difference in the two manuals? Should I be using grade 8 or higher bolts for a water pump? Any advise appreciated.
