Bolts for weights
seams you would be the best person to answer that by just measuring the holes and length you need instead of guesses.
Funny, I was just looking at the hardware required for my 1066 in the on-line parts catalog. Uses a special flat washer which I don't have enough of. I'd check the parts catalog if you want the correct hardware and not a hack job.
If you have both weights and tractor and know how to read a tape measure,you can easily figure it out.Your local TruValue store will have the hardware.
1/2"x3 carriage bolts will work on Cub Cadet, but Not on a Farmall Cub tractor. Cub Cadet uses 26# Cub
Farmall frt weights, Cub Farmall rear weight is 150#. I think they use 3/4" bolts, not sure of the
length.
(quoted from post at 06:28:27 05/10/18) Finally, someone who has access to the information and isn t afraid to share
You've got access to the information. I told you where I got it from.
I double-checked, and the parts book calls for 1/2" x 3" for the first set, or 1/2" x 6-1/4" for two sets of REAR weights.
The larger weights do use 3/4" bolts.
i am really curious why you need help to get bolts for weights? you dont need information when the items are in front of you, so easy.
