I'm working on a 700-B tractor that has sat for a LONG time. The crank will turn (by hand) just over 90 degrees. Having read about the injector pump sticking I didn't want to force it. I've taken the inspection window off the pump and the rear plunger seems to be stuck. I've also taken the long cap off the front and the fuel rack won't move. I sprayed it with penetrating oil several times over the last couple months and have been working on it several times a day the last week. From another post I saw about removing the screw and threading the bolt from the cover in the rack to have something to pull/tap on. Lightly tapping has gotten it to move slightly in and I've been able to pull it out just past where it was in the beginning. I've also taken the injector lines off and added penetrating oil there. Sorry for the long post but is there anything else I should try? Or just be patient and not tap on it too hard!
