Box Blade with Pulverizer Teeth
Hello, wanted to know if anyone had a few photos and/or information on a 3 point hitch attachment (combination box blade / pulverizer). We had a older piece of equipment that was red in color and was a combination Box Blade & Pulverizer. The attachment was very heavy, it had two rows of teeth (one on the front side and the second on the rear side) similar to a pulverizer that could be adjusted for depth, it also had heavy roller with ridges that would bust up dirt clods, it attached to the rear of the box blade and could be removed depending if needed. The attachment worked great for yards and gravel drives. The box blade part did not have blades like a standard box blade, just an open area to catch the material and redistribute it in low spots. The attachment was stolen along with a few other pieces when my Uncle passed. Trying to find something (info, name brand etc) similar so I can try to get another one.
Thanks for any information on this issue.
Check out the website for Landpride. They are a short line company out of KS or NE. I owned an implement like that years ago when I did lawn grading and seeding. Mine had two drums behind the 'H' beam with the teeth. They were also available with a single drum or roller. The drums, about 5 inches in diameter, had small bolts welded to them about 5/16 inch diameter and 3/4 inch long. When using a hydraulic cylinder instead of a fixed top link for the 3-point one could drag dirt to level or put more pressure on the rear rollers for a more finished look. It worked great!
