Box of torch tips
RedMF40
Not from Iceland!
This is for sale on FB marketplace for $25. I really don't need all those tips and a few look like they're the same. What I'd like to know about is that double-header. Never seen anything like that. What would it be used for?
This is for sale on FB marketplace for $25. I really don't need all those tips and a few look like they're the same. What I'd like to know about is that double-header. Never seen anything like that. What would it be used for?View attachment 169599
Google says:
The item in the middle is a dual-tip (or twin-tip) oxy-fuel torch attachment. It is an older, specialized attachment for an oxy-acetylene or oxy-fuel torch system, sitting in a box alongside several standard single-nozzle welding and brazing tips.
Key Features & Purpose
  • Dual Nozzles: It splits the mixed gas supply into two separate angled heads, allowing a single torch handle to produce two flames at once.
  • Wingnut Adjustment: The brass thumbscrew (wingnut) in the center acts as a clamp or swivel lock, letting you adjust the angle and spacing between the two nozzles to fit different workpieces.
  • Common Uses: Twin-tip attachments are typically used for brazing, soldering, or heating Cutting larger or round metal parts (such as copper piping or heavy joints) evenly from two sides at the same time, which speeds up heating and prevents warping.
Google says:
  • Common Uses: Twin-tip attachments are typically used for brazing, soldering, or heating larger or round metal parts (such as copper piping or heavy joints) evenly from two sides at the same time, which speeds up heating and prevents warping.
Thanks. I could see myself getting hurt with two flames going at once.
So I googled that. Dual head torch for machine cutting. From $150 on eBay to $1138 brand new from Airgas. I found the Airgas listing first, and thought, “ Sure glad I don’t need one.”
Google says:
Except the heads on the twin are not brazing, or heating type tips. They look like cutting tips. Also, a twin tip heating/brazing torch would have the heads angled towards one another, so as to heat something large and round. This arrangement cannot heat an object from two sides.
I give my vote to the twin track cutting arrangement mentioned by Jim.ME
I know, it goes to show how accurate Google really is.
I forgot to change that part before I posted it.
Sorry!
...And those are useless for DIP or stainless. Plasma cutting is the current preferred method, and lasers are becoming more portable every day, and will likely take over someday.
I'll bet if you were to google it 😁 , that's exactly why it wound up in a box of junk.
Wish I still did glass work. That twin head would have been great with a couple fan tips for heating/blowing large, round glass pieces.
Mike
