Jack Eslick
I recently purchase an 8n. The brake pedal for the right brake was lower than the left pedal and the brake was dragging. Removed the tire and drum and replaced the brake springs, but this didn't help. Next replaced the backing plate and brake shoes and all the seals and gaskets. The brake pedal worked OK until the hub nut was tighten. Figured it must be the brake drum, so I had it turned, but no success. Ordered a new hub and drum. The pedal is still exactly as it was when everything is tightened. The linkage does not appear to be binding.
Having replaced every part without any progress is frustrating to say the least. Any suggestions?
