Brake seal replacement help.
Brian Ski
The seal is leaking behind, I guess you call it the brake drum/rotor. I read do not remove the cast plate the seal fits in... Bad things will happen.
There are 2 seals there from the factory. My plan was to remove the outer one and leave the inner. Well, I got most of the outer one out and it is leaving the outer section of it with like a washer. It I drill and try to pull, I will destroy the inner seal.
Do I say go for it and take the inner seal out? Then do I need to replace both seals? Or is one modern one ok? I have searched through threads and don't see an answer.
ON WHAT?? Sorry but you have to remember you see the machine we don’t!
Edit: I see it must be a Farmall H due to your other thread, later these threads will be separated and no one will be able to know what machine was being discussed if it isn’t revealed.
Hello again!
Yes you are correct, do not remove the cast plate behind the brake drum. Bad things will definitely happen.
Yes there are 2 seals from factory. They should be a leather type double lip seal if original. Most likely both are leaking, so only pulling and replacing one doesn't do a ton of good, especially since it can be harder to get new seals in there the way you have it now. The seal design IH used is a bit confusing, but just pull everything out and you'll be fine.
I would recommend not drilling through that seal. The bull pinion bearing sits right behind that seal, so if you accidentally drill too far you could really mess up that bearing, and that would also not be a good day.
What I found works best on those seals is to use one of these. If you can fit it in between the seal and the shaft, or take a small screwdriver or a punch to make a hole in the seal (not a drill), these will pull the seals right out. Tool brand doesn't matter, a cheap one will work fine.
As stated earlier I would definitely replace both seals per side. You will be able to fit 2 seals back in, just make sure to grease the lip, then drive the first one in. On the second one, pack as much grease as you can into the inside part of the seal and grease the lip, then drive it in, then pack some more grease in between the two seals. This is because the second seal doesn't get as much lubrication if the first seal is working correctly.
Another note: when you took off the bolt and washer that holds the drum on, was there a cork gasket between them and the shaft?
And also, are you planning on doing any work with the brakes?
Please feel free to ask more questions if you have them!
What gives you the indication there are two seals in there? The parts book shows one but it list 3, at least on line. That means there is “one” in the position but the dimensions or something may be different for the seal or there were upgrades or superceded numbers for it. The original seals are thicker than the replacements so sometimes folks place two new style seals in the position where there was one originally.
Messicks Farmall H differential parts diag
But wait, I see what you are talking about, that 58154D is a cork seal to seal the splines.
58154D example
I see PbyIH has chimed in, I think what I am showing will be a bit of a challenge to his information.
Also if a parts book is showing “2 required” that means one for each side.
I haven’t had an H apart for 30 plus years so I could be wrong as well.
As far as drill the seal to put a screw etc. in it to remove it I think you’ll be fine if you’re careful when it pops through. Those bearings are pretty tough, a little drill bit kiss won’t hurt it.
58154D example
Hello Rick!
Glad to see you chime in, hopefully some of this will make sense.
"What gives you the indication there are two seals in there?"
-There is, in a way. It looks like one seal, but it's 2 lip seals enclosed in an outer ring. On the parts books, all a person can see is the outside ring, but there are two seals inside that ring. (The drawing for that seal isn't entirely accurate.) It's a matter of interpretation, technically it's one big seal, or 2 smaller seals inside a ring depending on how you look at it. Also, someone could've been in there before and put new seals in.
"The parts book shows one but it list 3, at least on line. That means there is “one” in the position but the dimensions or something may be different for the seal or there were upgrades or superceded numbers for it."
-Yes, the parts book lists 3, it looks like only one is offered though as the other 2 from Messick's are NLA.
"Also if a parts book is showing “2 required” that means one for each side."
-Yes, one big oil seal per side with two lips, as it came from factory. With individual seals now, Brian would need 4 seals to get the same number of sealing lips.
"As far as drill the seal to put a screw etc. in it to remove it I think you’ll be fine if you’re careful when it pops through. Those bearings are pretty tough, a little drill bit kiss won’t hurt it."
-True, as long as the drill bit doesn't go through to the balls. I just suggested the seal puller because it's easier and faster, and it tends to be more forgiving than drilling holes and putting screws in. I've tried both ways, and for me, drilling and screws did not work at all. Just my personal experience though, his might be different.
I hope this helped you, have a great rest of this beautiful day!
Through some internet reading said there are 2... (That does not necessarily make it so.) But I tried to take the first one out and save the second one... After you pull the first you can see the second one behind it. Like Used red said... the seals are steel with a band of leather in the middle of them.
But these Original are tough. (thick hard steel.) Hard to explain without a good picture... But I took out the center piece of the outer seal... And the outer piece is stuck in. Having a rough time with it. Like a crimped 2 part seal. That should not come apart.
I have worked on many automotive/truck seals before... This one is a little different.
Since this side is messed up I will try to get a picture of the other side... Might as well do both side... Also hard to say if the other side has been worked on before. The newer one I crossed to, is a double lip. So it may seal better.
As hard as the steel in this seal is, it is tough to remove. I think the ones we use now are made of thinner/softer metal. I never used a seal puller before. But with the shaft in the middle it may be tougher to fit in around it.
Thanks for all the help.
When I pulled the bolt there was a double washer... The thick one and the thin one. I did not get a good look, but the thin one was in good shape. It could have been cork.
Brake material looked ok at first glance. Mix... The right side was leaking oil and brake was wet. Left side was rusty and sticking. Plans were to replace the seals and clean them well. This is not going back to a farm tractor. It is my Son's and he wants to have it fixed up... It needs a lot of work... But I can't sit still.
Appreciate the help.
I think PbyIH said that. A couple of times on here I have seen folks saying “my new seals don’t fit part number says they are right” Then their picture shows the outer steel casing still in the bore.
A picture is worth a 1000 words. I finally pulled the second seal and the outer sleeve I butchered the heck out of it. Until I was done and figured it out. I was trying to just pull the outer seal with the sleeve. (I thought it was part of the seal.) That was a horrible mess. But got it out. Then I gave up and tried pulling the inner seal with the sleeve. Not sure if that can be done either. It would move till it hit the bent up parts of the out sleeve.
Basically it is 2 seals in a sleeve "pack".
Thanks for the video... It made it much clearer.
I think the best way is to pull both seals and then the outer sleeve.
Appreciate the help!!!
I looked again. No I did not see any cork gasket... What I was looking at was the washer... it was stamped kind of rough and looked like 2 pieces.
Congrats on getting the seals out! They are a pain in the butt.
As far as I understand, you removed a bolt, a small flat washer, a thick flat washer, then pulled the drum and that was it right?
In between the thick washer and the shaft there's supposed to be a cork gasket, like what used red MN posted earlier (link here). Without the cork gasket, oil can travel through the splines and out through the washers, leaking oil onto the brakes.
Here's the correct way things go:
Bolt - Lock washer - thick flat washer - cork seal - then shaft.
(^You might want to change this to a lock washer, and put blue Loctite on the bolt when reinstalling. Just my 2 cents.)
If you don't have those gaskets, you can either buy some or make some yourself out of cork, old inner tube, or whatever works. It's just mainly important to have some sort of gasket there.
I also saw in an earlier post you said "The right side was leaking oil and brake was wet." If the brake band is oil-soaked, you could possibly dry it out with a torch, but it probably will need to get replaced down the road. The brake drum probably will need to get deglazed too so the brakes work good.
Thanks for keeping us updated!
Yep, they are not near as easy as you would think. I am thinking the T style pulled would not work. Not strong enough. I used some screws and broke several trying.
I thought it was 2 washers... No, it was one thick one. It had a ridge on it when it was stamped that made it look like 2. I have some gasket material so I can make one.
At least I have experience for the other side.
I would show pictures, but these are way mangled up.
So many posts on the net that never have a follow up. Then you have a similar problem and wonder what the outcome
Drill down the best you can , then press ahead .
I like videos even if they are not that accurate . Use your experience and tools to achieve success. Think it through .
58154D example
I'd like to caution here, that an online catalog can get people lost in a parts search. It does not always list serial number breaks.
EX:
So, in this case, my '39, '40 & '49 all have different seal setups on the axle. There is no seal in the outer axle bearing cage on my early '39. The seal didn't become a part of the cage until after ser# 5985.
This could also change up method(s) of removal/repair.
And yes.... I know that's not brake seals. Just an example.
Mike
