Brake shoes
Wdj
With help from this forum I put new axle seals in the 3400 last summer. The brake shoes were oil saturated. Hosed them down with brake cleaner several times hoping they'd clean up enough to work and to run a bit to see if the leaks were fixed. Well, they don't. Before I order new shoes, does anyone know a way to clean them up? The drums have surprisingly little wear on them. I hear that the 2 inch shoes will replace the 1 1/2 inch. Is there any reason they shouldn't be used?
soak them in a pail of gas, then use brake clean. i have cleaned up some pretty oily brakes and they worked. you cant use wider shoes unless the drums will accept them.
I'm probably in the minority, but I would not fool around. They're brakes-just replace them. I live on a hilly farm-if my brakes don't work well, I can't operate on the hills. Mark
That's how I'm leaning. Bale a few places where I have to use the loader occasionally as an auxiliary braking device.
I use purple power degreaser for other parts . Boiling it in suitable pan containing 50 percent water percent purple power. I have now idea if this will work on brake shoes.
agree, start them on fire with a torch, did this with my JD 80 clutch pad and worked decent besides the discoloration on steel backer
Think I'm gonna get new but now I'm intrigued. So in the interest of science I'll try the torch technique just to see how it works. Thanks, I value the input.
