brakes on ford 3000
catriona
hello i am having aproblem with the brakes on my 3000 ford as in they dont stop the tractor, itook off the wheel but could not take off the hub thing someone told me there is 2screws holding this on but couldnt see them , does any know how to remove this hub thing and is there brake shoes on this tractor, with thanks
It should have drum brakes with shoes, just like older cars. The drum should just pull off after you remove the wheel. I might take some "persuasion" to break it loose from old dirt and rust though. I would put a board against it and hit the board with a hammer to try to loosen it. Don't hit the drum directly with a metal hammer, as it is cast iron and could crack.
Before you try to remove the drums you need to back off the expandable adjuster between the 2 shoes. It's just like an old car- you gain access to the star wheel through a hole in the backing plate and then you use a special brake tool or a screwdriver to back off on the star wheel.
You will also need to spray PB Blaster or similar where the axle flange passes through the large hole in the center of the drum. This area gets rusty.
thanks for the reply sean could you tell me if there are two screws holding on the brake hub thing as i dont see any might be covered in paint if these are sopose to be there. thanks
Awhtx is on the money. You have to back off the adjusters on the shoes so the hub will clear them. You can use a regular screwdriver, but it's handy to have the brake tool that looks like a screwdriver bent at about a 90 degree angle. If they haven't been removed in years, you will most likely still have to give it some persuasion with a hammer and block like Sean in PA said.
There are no screws in your 3000 brake drums. The 1954 NAA was the last tractor that had screws to hold the brake drums on while the tractor went down the assembly line. Everything after that used flat, sheet metal nuts (often called speed nuts) on 4 of the lug studs to keep the brake drums from falling off until the wheels were installed.
